HTXRamExp
I installed a front camera in my 2019 Ram 1500 Express Classic w/ the 4C UAS radio.
I purchased the camera, harness, and jailbreak module from Customtronix. I finished the install fairly late last night so after confirming that the front camera worked, I buttoned everything back up.
Today when I got in my truck, I realized that I no longer had my XM radio soft button, only AM/FM.
I pulled everything apart and double checked the connections at the back of the radio. I have the main harness black connector as well as grey, pink, yellow, white, and purple connectors. They were all in securely as far as I can tell.
I even unplugged the Customtronix harness and plugged back into the OEM harness and still did not have XM radio.
Which colored connection is for the XM radio? I suppose working in that tight space I may have disconnected the other end of the XM wire deeper under the dash?
Thanks in advance for any info!
