Lots of "lost communication" codes, Battery? PCM/ECM? Something Else?
jimbono
hawaii
My 2013 1500 tradesman with the 4.7 just started throwing a bunch of communication codes (at the bottom of this post). The dash gauges will turn on and off (speedo/tach/etc) and the display flickers as well. Occasionally "no bus" shows up on the screen as it boots up/shuts down. A bunch of warning lights pop up but the truck is running smoothly.
I initially checked my battery voltage at 12.35 volts, hooked up to a charger and now its at 12.5/12.6 or so. Battery is almost 2 yrs old. I cleaned the terminals (they looked clean already), inspected/cleaned the frame grounding point by the battery, unplugged and plugged back in the connectors under the steering wheel by the pedals and also the ones in the BCM. I pushed in all the fuses in fuse box and checked them for continuity.
Before I did any of that work, the codes included a lot of modules. After doing the stuff above, the codes are mainly limited to ABS/Traction control. They popped up even after a fresh charge and after a minute or two of running time. Do these look like my battery is going bad and causing havoc? Alternator? PCM? I'm inclined to think that with so many different modules there's a power supply issue or something like that. How would I know if my alternator were going bad?
Truck has had zero issues at all for 141,000 miles. I had it parked at a friends house for 5 days while I travelled, and it started throwing the codes when they were on the way to the airport to pick me up.
Here is a quick clip of the dash, but this is after the reset and the only persistent caution light is the traction control. Before I did anything above, the check engine light, traction control, and TPMS all stayed on. (TPMS readings were still visible on the computer though): https://youtu.be/t5xTCWj-XW4
Codes:
After the battery charge/cleaning/unplugging/etc (what's currently popping up on my scanner):
U1120 Lost Wheel Distance Message
U0002-00 Can C Bus Off Performance: No Sub Type Information
B16B7-15 Center Stop Lamp Control Circuit: Circuit Short To Battery or Open
U0140-00 Lost Communication With Body Control Module: No Sub Type Information
U0121-00 Lost Communication With Anti-Lock Brake System (ABS) Control Module "A": No Sub Type Information
C1501-96 Tire Pressure Sensor 1 Internal: Component Internal Failure
C1580-00 Left/Right Side Tire Pressure Sensor Location Undetermined: No Sub Type Information
C1581-00 Front/Rear Tire Pressure Sensor Location Undetermined: No Sub Type Information
C1504-96 Tire Pressure Sensor 4 Internal: Component Internal Failure
U0212-00 Lost Communication With SCM: No Sub Type Information
U0002-88 Can C Bus Off Performance: Bus off
U0126-00 Lost Communication With Steering Angle Sensor: No Sub Type Information
note: the TPMS readings just starting showing blank - they were all fine before I did any work, not sure if they just need to relearn since I haven't driven fast/far enough yet.
Before I did anything:
U0001 CAN C Bus
U1110 Lost Vehicle Speed Message
U0212 Lost Communication With SCM
U0001-00 CAN C Bus: No Sub Type Information
U0127-00 Lost Communication With Tire Pressure Monitor Module: No Sub Type Information
U0100-00 Lost Communication With ECM/PCM: No Sub Type Information
U11E8-00 Lost Communication with EPS Steering Torque Message: No Sub Type Information
U11B9-00 Lost Communication with RF Hub: No Sub Type Information
C1580-00Left/Right Side Tire Pressure Sensor Location Undetermined: No Sub Type Information
C2129-16 Battery Voltage: Circuit Voltage Below Threshold
U0415-00 Invalid Data Received from Anti-Lock Brake System (ABS) Control Module "A": No Sub Type Information
C2128-00 ECU Reset/Recovery Occurred: No Sub Type Information
U1141 Lost Brake and Torque Messages
U11BC Lost Brake Switch Message
U113E Lost Communication With Intelligent Battery Sensor
U0001 CAN C Bus
Black-Wolf
North Carolina
Sounds like a bad CAN Buss or bad CAN Buss Star Connector. There are several, and they act as a communications bridge between the various computer modules in your truck.
Jimmack
