Low Beam LED Headlight for 2011-2019 Ram 1500/2500/3500 Non projector, reflector housing
Underground Lighting
Supporting Vendor
Looking to upgrade your 2011-2019 Ram Headlights With non projector housing (reflector)? Need something brighter to see at night? We'll you're in luck. We know the the Ram's factory headlights Suck for visibility! Here is the best solution for visibility.
We are pleased to offer a plug and play, error and flicker free LED Kit.
Low Beam LED Headlight for 2011-2019 Ram 1500/2500/3500 Non projector, reflector housing:
https://undergroundlighting.com/pro...0w-6000lm-pnp-led-headlight-fog-light-drl-kit
We also offer fog lights to match:
https://undergroundlighting.com/products/h10-9145-9140-40w-6000lm-pnp-led-headlight-fog-drl-kit
What makes Our Kit Special and better than the rest?
Our kit is a true 40W 3000Lm Per Bulb, Fully adjustable 360 degrees. Easy Install! 1- Year Warranty
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
adjustable in quad headlights?
California
Hemi V8
Next mods on the list are head and taillights. I have the 19 Ram 1500 Classic. I'm open for suggestions, swap with projectors or convert my reflectors or swap out bulbs. Main goal is to improve visibility at night.
aidmyaim
Detroit
V6
Is that $129 per bulb or per set?
timpaine1
New york
3.0 l v6 diesel
I have a 2013 ran 1500 that has only high beams and the low beams move toward on if I move the tilt up and down. I believe its in the high beam button. I am confused in that reason!!
Supporting Vendor
I am sorry, But I dont understand your question. You have a 13 ram. DO you have projector or reflector housing? Your low and high beam bulb are separate bulbs.
Ram201963
