low oil pressure switch? 97 5.9l 360 v8
zeustheram
North Caroolina
5.9 360 V8
so im wondering if the 97 dodge ram 2500 had a low oil pressure "kill" switch? for the 360 v8's. that would cause the truck to not crank with low oil pressure even though its got 5 full quarts of oil.
Merc225hp
NA
truck
gas
Nope no Murphy switch on these motors.
Z
zeustheram
North Caroolina
5.9 360 V8
damn! cause i was driving to work this morning and i was on way to get gas well i felt my truck shutter like bump..bump..bump then the oil light flashed and went away right before i got into the gas station i pulled up to the pump and shut truck off popped the hood and checked the oil. Well oil was between safe and add after three times checking and reading the stick. so i got my gas went to crank the truck the truck wont crank and the oil lights staying on. its getting gas and spark but will not turn over. my dad had told me about vehicles having a low oil pressure kill switch and i was curious to find out if my truck had one. I need to figure it out cause im selling the truck soon so i can get a 02 dodge ram 1500 crew cab 4x4
Merc225hp
NA
truck
gas
So it turns over but won't start/run or it will not turn over? Check batt cables, try starting it in N not Park.
Z
zeustheram
North Caroolina
5.9 360 V8
it wont start/run you can sit there and keep turning the key and itll try but it wont do it. the gen light came on later today after trying it again
Merc225hp
NA
truck
gas
When you turn the key on can you hear the fuel pump run at all? It won't for very long but you should hear it. Or you can check fuel psi at the fuel rail, using a test gauge it should be 49 psi.
dodgetruck2
5.9 Cummins
Oil light will always be on when key is on engine off, cause you don't have any pressure
ohiogrown
ohio
2010 CCSB, 2011 ccsb, 2012 5500, 2016 5500, 2017 ccsb wxpress
4.7, 4.7, 6.7, 6.7, 5.7
So it won't crank or won't fire? If it won't crank that sounds like it could be bad news. Usually clank clank clank, oil light, engine won't roll is a bad sequence of events.
Merc225hp
NA
truck
gas
See post #4 &#5 and he found the problem the fuel pump is dead.
Z
zeustheram
North Caroolina
5.9 360 V8
i shot some starter fluid in it today and it almost started and ran so its not anything mechanical wrong inside the motor. found out my fuel pump wont turn on checked my fuses and everything checked the wires nothing is unplugged or blown.
ohiogrown
ohio
Yeah I read that and it was unclear as hell. "You can crank the key and it will try but not do it". Not do which portion, turn over or fire? That's why I asked.
Merc225hp
NA
truck
gas
Time to replace the fuel pump then ;)
Z
zeustheram
North Caroolina
5.9 360 V8
went and picked up the fuel pump tonight. putting it in tomorrow. and ohiogrown what i meant was: you can turn the key like youre cranking the truck but the truck will not start and run. sorry for the confusion. i replaced the oil pump in it today with a high volume pump and did a oil change and all that.
Merc225hp
NA
truck
gas
Your post #5 was fine the other was indeed a little confusing lol.
ohiogrown
ohio
Gotcha. At least the plastic tanks and quick connects on the 2nd gen make swapping the pumps a relatively simple process.
Merc225hp
NA
truck
gas
So are you going to drop the tank or lift the box? lol this will get things going.............
Merc225hp
NA
truck
gas
To me thats the best way, done this four or five times in the 19 years I have owned her. Please remember to clean the tank out before you put in the new pump, get all the gas out and wipe the inside of the tank with a lint free rag. Also do not put the last of the gas back in the tank that you take out, just in case it is contaminated.
Z
zeustheram
North Caroolina
5.9 360 V8
alright well there goes 8 gallons of premium gas haha. i know i have to the prime the tank by switching the key on and off a few times. is there anything else that i should know that is important.
