Lower ball joint
Grtrnd1
2013 1500 4x4. 6 inch RCX lift. 35-12.50-20s. 4.7. I had new tires installed 8 months ago and had the front end alignment done. Noticed the tires are wearing on the inside. Took it this morning and had it realigned and they showed me that both lower ball joints had play and he said my driver side wheel bearing is shot. I couldn't hear what he was hearing with the wheel bearing. I've changed plenty of wheel bearings and ball joints in GM vehicles over the years but I'm a first time Ram owner. Are these pretty much straight forward? Axle nut, brake caliper, brake caliper bracket, wheel bearing bolts, top control arm pinch bolt, bottom ball joint nut, press out lower ball joint with basic ball joint press rented from Auto parts store? Or does the lower control arm have to come clear off and use a large shop press? Thank you
