Lower Control arm 2015 outdoorsman
jlsalani
Hi... saw you company name in a couple of other posts and they recommended you. Looking for right and left front lower control arms for 2015 Outdoorsman. Time to replace them and am in the middle of getting all the parts for the Bilstien swap. On top of that guess I would also be looking for right and left outer tie rod ends (553980091AF) and upper shock mount (68185640AA)... I think. How does it work?
Joe Salani
AllMoparParts.com
- Benny
Supporting Member Supporting Vendor
All
All
Hi Joe,
I sent you a code you can use.
If you need part numbers please send me over your VIN and I will send links
Thanks,
Benny
J
jlsalani
thanks Benny
do I just order from the site then?
Here is my VIN
1C6RR7LT3FS628800
Looking for
right and left lower control arms
right and left tie rod ends
right and left upper shock mount.
thanks.
Joe
AllMoparParts.com
- Benny
All
All
thanks Benny
Here is my VIN
1C6RR7LT3FS628800
Looking for
thanks.
Joe
Yes please, Here are links to them
https://parts.allmoparparts.com/oem-parts/mopar-lower-control-arm-left-68298347ab
https://parts.allmoparparts.com/oem-parts/mopar-lower-control-arm-right-68298346ab
https://parts.allmoparparts.com/oem-parts/mopar-outer-end-tie-rod-kit-68185640aa
https://parts.allmoparparts.com/oem-parts/mopar-shock-upper-mount-55398091af
Rod ends and mounts are the same for left and right. Please let me know if you have any questions.
Thanks,
-Benny
