Lower Control Arm
joepizuro
Magnum v10
Was changing my Control Arms yesterday because they were bent from a little accident and can't get the Camber bolt out of the LCA. I read that I have to use a sawzall to get it out but I was wondering if anyone knew which bolt it is to be ordered.
Tried finding them on LCA truck and Chrysler parts but not sure if its a 36mm or a 46mm.
Also going to need a new nut too.
Trucks a 1995 Dodge Ram 1500 4WD 5.9L
Edit: Broke the bolt. Definitely need a new one.
mike2me
SE Wisconsin
318 - 5.2L V8
Time to get out the tape measure and get under the truck. I have my truck all tore apart so i can tell you what mine are when i go to the shop but we have different trucks so no guarantees it will work.
Stangshcky12
Oshkosh, WI
5.9 Cummins
I just ordered all new control arm hardware from spohn performance
I would think they have the 1500 can bolts too
Also try rock auto
They aren't cheap unfortunately
J
joepizuro
Magnum v10
Since I didn't get the bolt out yet and I don't plan to until I get the new one. (Got a lot of work the next few days) Do these certain bolts come with the washer thing built onto one side?
I have the washer from the nut side. So ordering a new nut and bolt. Just wondering if I'll need a new washer for the bolt side also. Never worked with one of these types of bolts before.
J
joepizuro
Magnum v10
Thanks man. Ordered them
55-1014 NUT-LOWER CONTROL ARM $1.95
55-0407 BOLT-LOWER CONT ARM-TO AXLE $34.95
Total w/ Shippn $ 47.65
KevinM
5.2 Magnum
I had to order a new bolt for my wife's Ram from the dealership. Came in the next day and it cost only $5.
Hemi Ram
South Shore, MA
2006 Ram 1500 Quad Cab 4X4
Just replaced the lower control arms on my 06 and replaced all 4 bolts. I had to cut 2 of them off so I just replaced the set. I also replaced both lower strut mount bolts as well.
Sent directly from my thoughts using tinfoil antennas and a stainless mixing bowl helmet.
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Don't the 06 hemi have IFS? So it is totally different then us solid axle guys?
Hemi Ram
South Shore, MA
You are correct but I saw the picture in the thread of the eccentric bolts and they are extremely similar looking. Posted before I knew where I was. If it makes you guys feel better we share a similar problem though...
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Well maybe hit up a pickandpull and grab the bolts from out of a truck like you instead of spending $$$ on new bolts
ChloeBrooks
