map sensor
Karolvernon
Check engine light code indicates map sensor Check connection little loose afterwards check engine light went off but came back on later noticed small rubber line is crimped could this be the problem
Alexslo1k
Miami
yes this can cause an issue. Your MAP sensor needs to read the air moving through it. It measure vacuum, if you crimp the line supplying the air then it will throw a code.
joshhhh
