Master window switch pins
Syke001
And one know when to find out what pin does what function on a driver side master window switch panel a photo would be Nice ?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Fast69Mopar
What year, make and model truck do you have?
If you can PM the VIN to me I can pull up the wiring diagram and post it in the thread.
I also think that you didn't look at the Mopar Connector website properly. If you select the year, make and model of your vehicle it will pull up every single available connector for your truck and once you click on that connector link it will display the connector pin out as well as the circuit identification.
I went to the website and selected a 2022 DT Ram 1500 and scrolled to Switch - Window/Door Lock Driver and this is what it shows... IMG_20260320_125838.jpg
S
Syke001
I went to the website and selected a 2022 DT Ram 1500 and scrolled to Switch - Window/Door Lock Driver and this is what it shows... View attachment 581545
The problem is I have an after market power window set up and want to up great door panels with power window switches but need to know what pin is power ground and switch up/down for the drive window and passenger and locks no rear windows
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
That site should tell you all of those things.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I have go over it and it’s just not clear to me maybe I’m reading it wrong but what’s I don’t get it
Got it, that info is in what @Fast69Mopar posted above for his truck BUT I don't know if and aftermarket solutions is compatible with the factory wiring (specifically the LIN BUS). Are you saying you want to remove the aftermarket and add factory?
S
Syke001
I have aftermarket power windows but I want to use the stock window switches not the aftermarket switches but I don’t know what pin is for what in the factory switch panel. These photos are of passager side
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Honestly, I'm not sure how the factory window switches operate (if they are analog up/down or receive a message of the BUS). What year did your switch you want to use come from?
S
Syke001
A 2014 ram regular cab
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Aftermarket to OEM is not as straight forward and simple as some may think.
In the OEM setup, the switch doesn't control the window. It tells the door module and computer what signal / control to send to the window motor. The motor then sends signals back to the computers via current draw showing it is at it's limits to turn off operating up/down power.
Aftermarket ones are any man's guess unless we know exactly what they are and what controls them.
S
Syke001
Damn I was afraid of that. So I would need the door regulators modules and program the ecu right ?
04fxdwgi
2016 1500 Sport
A at a minimum, yes. Programming is not done in the ECM / ECU / PCM. Don't forget the correct wiring harnesses and fuses / circuit breakers, also.
Both the BCM and TIPM will need to be programmed and the appropriate outputs in the TIPM activated.
A job not for the faint of heart.
stevenmicheal
