mcgaughys 2/4 deluxe kit
15ramrt
SoCal
whos running that kit and how do you like it? i probably shouldve asked this question before i ordered my kit but its still worth asking.
Milt IV
TX M'F'er
2015 Sport
only negative thing I have really herd is that since it is a spindle kit up front it pushes your wheels out a little bit.
Crashno1
South Florida
2014 R/T
I have had that kit on my truck from the 1st week i had it, 16 months. Rides great , looks even better.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Aside from the front wheels sticking out, it is a nice kit. It doesn't sit quite as low as the Belltech, but it rides nice and is easy to align.
Statcher1
Kentucky
I'm running that kit. It does push your wheels out about a half inch on each side. And like Matt said it don't sit quite as low as the Belltech kits do.
15ramrt
SoCal
is it the increase in track width up front obviously noticeable?
charonblk07
Calgary, Ab
F1-A forged 349ci
The fronts don't tuck into the wheel wells anymore. I just run a 1/2" spacer on the back to even it out and have been this way for 2+ years.
15ramrt
SoCal
has anyone with this kit cut the factory spings as well to give it more a of a drop?
Tray Burge
On the porch
Same kit I got, did the 1/2" spacer in the back to even out the tires.
charonblk07
Calgary, Ab
F1-A forged 349ci
Sorry, don't have any with me for another week as I'm out of town for work.
Yes they have, several 4/6 dropped 2wd rams rolling around with spindles/trimmed springs up front and trimmed 4" drop springs in the back. Going that low you run in several issues that affect the ride quality though and really require some fab work to make it right.
15ramrt
SoCal
im not trying to go that low. if anything i would cut the stock springs an inch maybe and same in the rear. but im gonna get the truck tomorrow and ill see how it looks after it settles. as far as the rear spacers, did you get extended studs in the rear?
ramittome
Gonzales, LA
Did it on my 2013. Had the front dropped 4" and the rear 5". Plan on doing it again to my 2015 when I get the money.
15ramrt
SoCal
sooo....... the trucks been lowered for almost a week now and even though it rides great, im not fully satisfied with the stance. i want the front end to sit a little lower, like another 3/4 of an inch. should i just cut the front springs or does somebody make a 1" drop spring? id rather just buy more springs instead of cutting my stock stuff.
i just came across these. anyone hear about em? used their products?
http://www.crownsuspension.com/lowering-kits/2009-2015-dodge-ram-1500-1-front-lowering-springs/
moregrip
can we get some pics up brother!:favorites13:
charonblk07
Calgary, Ab
F1-A forged 349ci
razor1
St.Petersburg Fl
2009-2014 Dodge Ram 1500 1" Front Lowering Springs
helper bags in the rear can give you 3/4" gain at 35 lbs or so
Txhemirt
Lubbock, Tx
Did you install a rear sway bar
Ghstrdr95
