MDS at fault ?
Jds9911
Oklahoma
Just had my 5.7 rebuilt. The engine builder did not upgrade the cam or lifters to non mds, at my disappointment. He did remove the solenoids and put in the plugs. Now, when the engine builds oil pressure it only runs on 4 cylinders. Any ideas I should discuss with the mechanic.
Hemi395
Cape Cod MA
Yeah that sucks. You can't put MDS lifters in with the MDS solenoid block off plugs because it will do just that, run on 4 cylinders all the time. The MDS lifters use oil pressure to collapse for MDS mode and without the solenoids there controlling oil flow to the lifter bores, they will get full oil pressure all the time and stay collapsed.
Definitely bring it back to the mechanic because it will be a V4 until you get MDS solenoids installed.
Burla
2010 Hemi Reg Cab 4x4
He has to make it right, or file a small claims case asap. what a bummer
btw, how does it run on 4?
WY.Ram
Larkspur, CO
6.4L Hemi
Not only will it be a V4 forever but a V4 destined to destroy itself. Without spring pressure, the MDS lifters will 'jump' off the cam after peak lift at higher rpm. I would not drive it if it were mine.
Definitely a bummer, going all the back in I projected as my worst possible outcome, well aside from catastrophic failure that is. I do lots to keep from having to. Good luck
David_Jacobs
Calgary
If that’s truly the case I’d be very concerned about other areas of the build. I’m very surprised it’s not backfiring and throwing a code, as the solenoids are not there. I wouldn’t run it at all.
StickyLifter
TN
5.7L
I wouldn't drive it above about 2500rpms for sure. Add the MDS solenoids back in and it will work correctly.
DILLIGAF
Canadian Forces
Canada
This is why you dont ever let anyone work on your truck ! What a ******* moron.
