Measured Ny Tongue Weight For Fun
John Jensen
San Diego County
Ecodiesel
No special washers, no head tilt adjustments, no torqueing hitch head bolts, easy adjustments, true tongue weight measurement, no guessing....yeah, I really want to give this a try.
I've used Equal-I-Zers for years and they do a great job. All of OC455's points are the annoying things about the Equal-I-Zer but once dialed in keeping the head greased and the head bolts properly torqued is the only ongoing infrequent maintenance.
I have Weigh Safe's 180 Ball Mounts (no scale) on my trucks and they are excellent quality and heavy-duty. I expect their WDH would also be.
I also didn't know they made this WDH and for all the above reasons I would like to try it. The extended length from the truck is a plus for me for tight u-turns and reverse maneuvering. All that said, I agree with jejb that it doesn't look like a very robust sway control system and I too would like to hear more about that in actual use. The Equal-I-Zer has excellent sway control. A weak sway control would prevent me from trying the Weigh Safe WDH.
Loudram
Just a sinner saved by grace
Navy Badge
South Jersey
Hemi 6.4L
Doesn't look like a very robust sway control system. I'd wait for some feedback on that before I'd consider an option.
Very true and I would.
OC455
OC455
Central NY
My TruTrack has a similar sway control setup, and I dont have an issue with the way it performs. That's why I like the way this looks.
Not bad mouthing other designs at all, from everything I've seen, reviews and read the Equal I Zer is top notch. I like my TruTrack too...it still performs well.
The hitch looks like it bumps you out a good 8 inches but I dont think that is too awful considering the amount of tension is being used on a WDH in the first place.
If I ever get money ahead, will be looking at this for sure.
pepep
