MMX's dual pump system for the hi-po guys
Modern Muscle Xtreme
10h ·
https://www.facebook.com/#
New Product!
MMX is proud to announce our Dual Pump Fuel System for 2009-2024 RAM Trucks! This system features twin 285LPH (Hellcat) fuel pumps for max power capability! This system will flow enough fuel to handle 1100 WHP on E85. This MMX Dual Pump module is designed just like our tried-and-true Hellcat Dual system, with a fuel basket! This basket features a larger capacity over stock, along with a secondary jet pump (venturi) system that ALWAYS keeps the fuel pumps supplied with fuel! No more low fuel level stalling or surging issues with this system. To power this system, MMX has designed a fully plug and play wiring harness! This OE quality harness will plug into the existing fuel pump power connector, the existing trucks Fuel pump control module, and will include a secondary fuel pump control module to control the second pump. This system retains the factory PWM (Pulse Width Modulated) fuel pump control system which helps both provide extend fuel pump life! Our RAM Dual pump system features an OE fuel line connection, for a simple plug and play installation. For RAM owners looking to make over 850 WHP, MMX recommends upgrading the Fuel Feed line to a -8AN, or -10AN feed line, and converting over to an upgraded MMX fuel Rail pressure sensor. No return line is needed when upgrading the fuel line, only a single feed line! The top of our fuel pump hat is equipped with a 8AN ORB fitting, for ease of upgrading fuel lines in the future.
https://www.modernmusclextreme.com/p-1935-2009-2024-dodge...
All reactions:
40You and 39 others
MOPAR78
2014 Ram 1500 4x4
6.2 Demon
10h ·
New Product!
Check it out View attachment 562591
All reactions:
40You and 39 others
Nice!! A few years late for me but glad to see it is offered!
