Mopar 82212184AB Installed on RamBox 1500 CC
Farmer Fran
Earth
2025 Limited Longhorn
SST H.O.
I just finished installing the Mopar Hard Tri-Folding 82212184AB Cover
Installation (RamBox) took maybe 20 minutes. Only takes a phillips screw driver to install.
Things I really like about the cover
Hard cover. Though I would not put a lot of weight on the panels
Canvas Topped. Looks way better than vinyl.
The clips that hold the cover when folded are attached directly to the frame and not on straps <-- I hated this about my other tri-folds. The clips that are on the top of panel 1.
The latches are super easy to use and lockable so that it would make it "harder" for someone to steal the cover when in the opened position
Embossed Ram head on the back panel
The item was well packaged in the box
Instructions are super easy and clear
Other notes
My cost was $850 OTD <-- well worth the price
The cover is not hella-flush it sits up above the edge about 1"
Farmer Fran
Farmer Fran
Earth
SST H.O.
Pic coming soon
huntergreen
Marine Corps Navy Badge
i like the embossed ram head. look forward to pics.
Farmer Fran
Farmer Fran
Earth
SST H.O.
GQhFdK4G5Vo7U4Nz9
Firebird
2019 Ram 2500
I have the same cover for the non Rambox bed, love it!
Farmer Fran
Farmer Fran
Earth
SST H.O.
Ok, I've had it on about a week now. Easy to fold and lock. Easy to unlock. More things to note.
The straps, like I said earlier, on the top are direct mount, not on any tether. The locking straps have a button to keep them from just dangling went the cover is closed they are also the correct size so no need to pull the end to tighten.
There are 2 handles to unlatch on each side but when you fold the cover once they slide back them lock into a channel to keep the flush.
Farmer Fran
Farmer Fran
Earth
SST H.O.
What's it do when opened? Go against the rear glass like Bakflip?
No.
The 1st panel stays flat like most tri-fold covers. So in essence you get 2/3 of your bed when folded. For me that is not a big deal as the cover is super easy to remove and I am not ever surprised when I need the use of the entire bed. So I just take it off.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
If it were flush it'd be better...and if it folded up it'd be perfect.
Farmer Fran
Farmer Fran
Earth
SST H.O.
If it was flush you would lose too many of the awesome features (that I enjoy).
If it folded up it would be heavier and more awkward to enjoy and remove. As well as be heavier on a truck already limited by its GVWR.
actually on the RamBox the anti-flush works better.
Farmer Fran
Farmer Fran
Earth
SST H.O.
I have had it on about a month now. Pretty water tight in rain storms while driving city speeds, highway speeds and sitting still. I have taken it off once to help someone move. Very easy to remove and reinstall.
Still very happy with it.
blackbetty14
CT
Hemi 5.7 VVT/Etorque
Roll ups 4 life FTW!
dakota18
