more audio trouble !!!!
ramhunter9
ramhunter9
P-Star Jeep Wrangler
stay away from shallows. find a good sub that has normal depth of 6"
nothing wrong with shallows . read up young man ... 12volt.com
ramhunter9
ramhunter9
The polk looks like a good option. Your box having only 6.375 mounting depth is now your limiting factor on what subs you can go with. You basically need low power (small magnet) or shallow mount 12" subs. I would recommend RF, but since hat is what you just had an issue with, get the polk they make good ****.
i love my door speakers they are polk , they sound great , so i figured to try the subs
quietpeen
2021 TRX
Hellcat
butch , will the 4ohm polk i have listed work out ? it calls for .88 ft of air space same as my box and will fit
no because that sub is 4ohm with an rms of 425 watts. If you wire that amp at 4ohms you will only get 200 watts. You would want that sub as either a 2ohm SVC or a 4ohm DVC.
glass3222
Central PA
Many moons ago I had some Polk DB subs. They sounded good and held up well.
Shallow work well, BUT if you had more depth available I think you could get a better sub for the same price what would be crisper and just sound better. But shallow subs have improved drastically over the years.
ramhunter9
ramhunter9
butch ...it is a 4 ohm dvc ...
ramhunter9
ramhunter9
and to wire it its like JJ's post #8
quietpeen
2021 TRX
Hellcat
yup....exactly.
This still sucks man.
glass3222
Central PA
Yep.
Then turn down the gain on the amp to about half or a little less than half way. Turn your stereo up to about 3/4 max (your door speakers should not be distorted). Then slowly turn up the gain on the amp up until the sub just starts to distort, then back it off (usually about 1/4 turn).
ramhunter9
ramhunter9
butch , tell me about it ...its only money ..
ramhunter9
ramhunter9
Yep.
10-4 .. thats what i do anyway lol just couldnt do it to this sub
quietpeen
2021 TRX
Hellcat
Yep.
also start with the bass boost low....that can easily start to cause distortion
true.....but the waiting sucks balls.
glass3222
Central PA
Cool. I was just making sure, you would be amazed how many people I have seen install their system, turn the gain and bass boost all the way up, start turn their radio on and crank it. Then the wander why it blows the subs or sounds like ****.
ramhunter9
ramhunter9
yes it does .... sucks i have no boom boom
ramhunter9
ramhunter9
ill sell ya a rockford P3 lol
ramhunter9
ramhunter9
it looks pretty ?
but side note ..i dont want JJ to feel its his fault .. i dont know what happened . lets just chalk it up as freak thing
i will buy from JJ again .
quietpeen
2021 TRX
Hellcat
yeah definitely...JJ is a good guy. I bought a superchips from him
ramhunter9
ramhunter9
one of the finest
Jantelaw
