Kalvin
Hey everyone, I have a 2016 ram 1500 which had stock reflector headlights and I wanted something more aesthetic so I bought the morimoto xb led ones cuz they make it look a lot better. Everything worked fine while installing but now every time I start it I have to manually turn on my lights via the dial and flash my brights once or else the display cluster will tell me my high beam headlight is out. Then when I go to check the lights by getting someone to flash high beams, only my low beams work(high beams don’t turn on). I talked to morimoto about it and They sent me a new wire harness that does the exact same thing. Just wondering if anyone else has had the same problem or if it’s just me and or how to fix it. Thanks
