Motors
My1stbuild
I have a 2003 dodge ram 2500 2wd quad cab with the 5.7 hemi. My question is... I found a set of motors one is a 04 the other is a 05. One came out of a truck the other came out of a box truck. One motor looks to be the same as what I have but will need a new crank because of a faulty rod bearing.. The second has a different timing cover and harmonic balance bit seems to be the same block as far as I can tell. Was told it had a miss fire but ran and drove. (This is the one I wanted to freshen up) My main concern is.. Are these motors the same internally? Can the parts,pistons,and heads interchange? I can change everything around if need be but I want to be sure before I rebuild a motor it will work in my truck. I want to be sure they are worthy of putting money in.. If In fact I can use them I have no problem doing a rebuild.. I have never built a motor before so any help would be greatly appreciated.. Thanks ahead of time.
Sent from my SM-S727VL using Tapatalk
HemiLonestar
Navy Badge Coast Guard
MD
04 and 05 1500's or 2500's? This will matter for EGR, otherwise internally yes. Can you post a pic of the one that you said the timing cover looks off on?
chrisp2493
Always Modding
Warren, OH
392 Hemi
Block and rotating assembly is all the same 03-08 on the 5.7 hemis. There are some differences with valve covers and coil packs from 03-05 and the 06-08 but they are interchangeable. EGR was added in 04, and MDS was functionally added in 06 to the 1500 trucks.
I Bleed Ram Trucks
HemiLonestar
MD
I Bleed Ram Trucks
Physically yes, but you know personally that the connectors aren't the same and there aren't adapters to go from 06+ coils to 03-05 coils lol
EGR was added to 1500's, the 2500/3500's didn't get it (no idea why)
