Mud Terrain with cold 80 PSI max
AJHeating
cummins 6.7
I have a 2015 2500 and I am one of unlucky ones that has not found a dealer to lower the pressures on the TPMS system. I have a 5" Fabtech lift and was running Toyo 35 RT's. I would like to let anyone know that I found (and installed) Nitto Trail Grappler 37x11.5 that have a 80lbs max cold pressure. This is also without no trimming on a 20x9 rim with 5" BS. They also make a 35x11.5 size tire. I can understand that a lot of people like the wider tires (12.5, 13.5, etc.), but i like the look of the taller/narrower tire. They said they are fairly new to market to meet the higher pressure thresholds on the newer trucks. thought i would pass this on. thanks
Ratket
Arizona-
Are u running them on stock 20"s?
