Hawki1cr
Just finished installing the mufflex dodm80. Install was easy and truck sounds great!! I know leaks can be an issue with mufflex. I tightened the clamps with an electric impact but when I started the truck for the first time after the install, water was dripping from all three clamps. I assume this is not normal and is a sign of a leak. Is it normal for exhaust systems to have this much water in them?
What can I do to fix this? I didn't use the rtv stuff. Would that help? I don't want to weld it.
