Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
which is a good band clamp to use for the mufflex dodm80...i keep reading that the front one that comes with the kit always has a leak any help would be appreciated.
Be carefull using a band clamp with the stock pipe... there is a small stud or factor nipple that keepss the oem muffler in a groove. If this isnt removed the band clamp is worthless.
I had my delete pipe notched so it would work the same way, then put the band clamp similar to the muffler, just to the rear of the nipple, and in front of the nipple on the rear pipe.
