RJL1
- Joined
- Dec 6, 2014
- Posts
- 453
- Reaction score
- 538
- Location
- Jersey Shore-By the beach
- Ram Year
- 2018
- Engine
- 5.7 Hemi
Double post.
Truck looks great! Tires fit perfect with the flares [emoji1362]
That is very clean. I really like that look!
Truck looks great! Added my lift earlier this year and handled it as a DIY. I am planning on adding the fender flares as well but will go with the rivets. Looking at a set from Rock Auto.
Yes it is....Thank You for Posting This Pic
Yep, as others have also said - that's a good looking truck! I too was going to buy the Fuel Assaults but found the TIS Off-Road 544BM and went with that. I am still waiting on them to come in and sure hope I made the right choice. Yours does look good with them on it. I'll also be adding BW fender flares to cover the overage because Hawaii has a thing about rubber sticking out past the covering.
Thanks....That's a good looking rim. Are you still waiting for the BDS lift to come in? The anticipation killed me after the 1st month
I'll stick with a good ride. Lifting looks great, but I prefer function over form. If you can do without the precise engineering that goes into a truck, lift away. Just be prepared for a bad ride if that does occur (and it usually does.) If I really needed the truck lifted, I'd get the versions from the factory that have been well-engineered by the OEM that have the 2" lift already on the truck.
I'm not sure about your year but, I have a 2017 1500 4x4 with 6'4" bed.
I can fit my BFG K02 35" full size spare under the bed.
Have you tried to put yours there?
Mine just fit with about a Popsicle stick thickness of space to spare.
Interesting...I'm running 35s with just a level and I don't see much difference in height? I'm doing a 4" tomorrow, I don't think I need more than that.
Your truck looks great BTW.
