Mysterious unlocking and window opening.
Robert D Lescombe
Canada
6.7 Diesal
2010 Ram 3500. Doors unlock and front windows open when no one is around and truck is parked. Can't seem to find anything on this.
lpennock
Army
Phoenix, AZ
5.9L & 6.7L Cummins
Key fob going bad. As you move with it in your pocket it triggers unlock button.
Sent from my SM-T500 using Tapatalk
Firebird
2019 Ram 2500
And I believe the fob also has the windows down feature like my 2011 did.
Reactions: BWL
R
Robert D Lescombe
Canada
6.7 Diesal
My FOB doesn't have a windows down feature and I changed to my spare FOB and it still happened.
mtofell
If it does it with both fobs maybe the receiver shorting out/going bad. Also, when you switched fobs was the first one still in range? I'd take out the battery just to rule that totally out.
As for the auto-down windows I thought Rams had that until about 2013. I suppose it's possible yours had the hardware but not a fob... meaning it could be getting triggered if the receiver is going haywire.
Or..... maybe you have a crazy ex who made a copy of your fob screwing with you?? :)
R
Robert D Lescombe
Canada
6.7 Diesal
It seems one of the fobs was the culprit although why the windows were opening is a mystery. There is no window button on the fob. Thanks for the help.
clifford15
RI
CTD
If you press UNLOCK twice then hold the front windows should go down, with either FOB. I think they disabled the feature in 2012 but it can be reactivated with AlfaOBD on newer RAMs.
Reactions: BWL
Burla
2010 Hemi Reg Cab 4x4
Another suspect is TIPM, usually it isn't a relay but the solder joint in the TIPM. Find the relay and bypass it for an easy fix, cig lighter is one option, but since I dont think it is hot all the time the door lock wouldnt work. either way I would pull relay until I can fix it.
