shinglelayer
- Jul 13, 2011
- 17
- 0
- 2002
- 5.9L
I have an 02 Ram 4x4 1500 with a 5.9L(gas) with auto tranny. If I park outside overnight, in the morning it dies in reverse only. Park, neutral, and drive it runs fine. It only happens on nights with temps below 30. After it warms up, it is fine. Doesn't happen if it sits at work for 8 1/2 hours during the day. Also, it hangs in 1st gear for a couple of seconds before shifting. Shifts fine to 2nd, 3rd, and 4th. Also, if I floor it, it downshifts to 1st gear, regardless of speed. Tranny fluid and filter changed about 5000 miles ago and the fluid is at max line, so it is not low. Don't know if this is 1 problem or 2 separate things going on. There are no CEL's and no codes have been thrown. With all the electronics on these newer trucks, I have no idea where to start. Any help is greatly appreciated. I have read posts with similar problems referring to TPS or IAC, but my problems have just enough difference, I don't know if that would cause my problems or not.
