Need help 05 cummins
Rodeo12
Cummins 5.9
I need y'all help here I have a 2005 5.9 cummins my lift pump went out so bought a new in tank pump ran fine for a week then started getting hard to start. Then I came out of store and truck would not start at all so I bought starting fluid got it to start got it home took valve cover off and I noticed a bent push rod I then took head off and checked over motor everything was fine put new head gasket and head bolt put it all back together and now it won't start at all even with starting fluid. Motor was rebuilt 8000 miles shop couldn't figure it out said I'm getting fuel pressure no code at all.
BWC
Northern CO
Cummins
So the injectors are getting pressure but not firing? Do you have a rail pressure gauge?
