NEED HELP! 8.4an Update 13.58.52
Kingcobra423
Long Island, NY
2013 1500 Sport CC 4X4
5.7L V8 HEMI MDS VVT
Hello All!
Does anyone have the an 8.4an update prior to 13.38.52?
I did the most recent update (13.38.52) but I want to revert back to a previous version. I want to turn my "ECO" light on. Once I did the update I seem to have lost the "Fuel Saver Display in Cluster" option. I'm not 100% sure the option was there before because I only had the truck for 2 days before I did the update. But I'm getting the runaround from Ram and the dealership and want to try this 1st before I bring it back into the dealership.
I was hoping someone has a previous firmware version that they could share with me...
Thanks!
Coop
Omaha
I have the latest update and still have the ECO light.
The ECO light is there if you had the option selected prior to doing the update. The issue is that the latest version, there is not an option to turn it on.
Kingcobra423
Kingcobra423
Long Island, NY
Exactly Coop, thank you!
jsequino
New Hampshire
2019 Rebel
5.7 liter V8
I have the latest version and it's not there. Last night I reinstalled the latest version 13.38.52 to see if I could fix another issue I was having. After it finished installing I saw the "Fuel Saver Display in Cluster" option so I checked it. This morning while driving to work a green ECO started showing in my cluster. I have no idea why it's showing? Is that some sort of way of telling me that I've saving gas or something? Anyhow, I found it really annoying so I wanted to turn it off. And now - it's no longer an option when I search for it. Very weird. I'll do another re-install of 13.38.52 tonight and hopefully it shows up again in the menu choices long enough for me to turn it off.
kenwitter
Cananda
The green eco light comes on to indicate when you're driving in the most fuel efficient manner.
Sent from my SGH-I337M using Tapatalk
Kingcobra423
Kingcobra423
Long Island, NY
That's my exact issue! You hit the nail in the head! Once I installed the update the "Fuel Saver Display in Cluster" disappeared! Frustrating for those people like yourself that turned it on, and now can't turn it off. Frustrating for me because I want to turn it on, but now I can't!
jsequino
New Hampshire
2019 Rebel
5.7 liter V8
If you still have the 13.38.52 update, just install it again. Last night I re-installed 13.38.52 again (3rd time) and sure enough the option to Display Fuel Saver in Cluster popped back up. I quickly unchecked it - I found the green ECO thing really annoying. And this morning, the option to check/uncheck is gone and the ECO light is off - so that's good. In your case, since you want the ECO light - I think this is the way to go. Sounds pretty convoluted but it's worked for me. Let me know how it goes.
Kingcobra423
Kingcobra423
Long Island, NY
Ok cool, thanks man! I'm going to try that tonight. How/when did you turn it off? Theses are the steps I took to do the update...
1) Start the vehicle.
2) With the engine running and radio powered on, insert the USB Stick with new software into USB hub.
3) The next screen display will have the old and new software levels.
4) Press the soft key “Yes” to start the update.
5) After the update is done, the screen will display the software levels again.
6) Press “No” and turn off the vehicle. Open the driver's door and let the Bus go to sleep. This will complete the radio update.
7) Remove the USB update stick, the update has been completed.
After which of the above steps did you turn off the ECO light?
jsequino
New Hampshire
2019 Rebel
5.7 liter V8
I didn't have the engine on at all. Here's what I did:
1. Insert USB
2. Turn ignition to RUN
3. Wait for the screen to come up to ask me to do the update. Press Yes.
4. Walked away and came back 15 minutes later when it was done.
5. Pressed NO when it asked if I wanted to do the update again and took out the USB.
6. Went to the Display options and checked/unchecked the ECO thing
7. Turned the ignition to OFF
8. Started it the next morning and went to work.
Done
Good luck!
Kingcobra423
Kingcobra423
Long Island, NY
1. Insert USB
Done
Good luck!
Thanks man! I'll give it a shot... How'd you make out with your heated seat & steering wheel?
Kingcobra423
Kingcobra423
Long Island, NY
It worked! You're the man jsequino!
jsequino
New Hampshire
2019 Rebel
5.7 liter V8
Excellent! Glad it worked. Me on the other hand - no dice with the heated seats. Supposed to get some snow tonight and we'll be out at a party. Maybe the heated seats/wheel will magically work when I do the remote start from my phone....
I also asked the service manager at my dealership if there are any updates for the issue. Time will tell...
Kingcobra423
Kingcobra423
Long Island, NY
Was it below 40° degrees this morning when you started her up? Did you try checking the box with the ignition in the run position but with the engine off or vice versa?
jsequino
New Hampshire
2019 Rebel
5.7 liter V8
My garage is heated so the truck is never below 55 in the mornings (which is very nice in New Hampshire.) It should be below 40 tonight when I get out of this party.
Yeah I tried checking it in RUN/engine off, ACC/engine off, and with engine on. No dice. I even just did a factory reset earlier today (by holding the heating and cooling buttons for driver and passenger it opens the Engineering Mode) and it still wouldn't stick. Something crapped out somewhere. Waiting to see what the dealer guys say.
