Need help wiring two 130 watt lights please
TXKID
Houston, TX
I have never really had the "know how" to wire up any sort of lights and I was hoping someone on here would be kind enough to give me a list of what I would need for two 130 watt lights and what connects to what. If somebody could help me I would really appreciate it.
GhostRam94
Hunstville, Texas
2009 Laramie CC
dude if you need any help with this i can come by and give you a hand man..... ive done wuite a few of these and i can do mine while im at it lol
TXKID
TXKID
Houston, TX
Thanks jj!
And Jeremy, I'd totally ask you to come over but I'm back in Houston doing it
TXKID
TXKID
Houston, TX
Nah I have to take care of some stuff in cypress
Muddinginamopar
Wilkes-Barre, PA
Search the local auto parts stores for a relay kit. Makes everything so much easier. Instructions should be included as well. Make sure it's rated for 130 watts. Or, take the watts and divide it by the volts. So 130 watts/ 12 volt system. Figure out the number, and that's how many amps you'll have. Throw an inline fuse rated for a few amps higher onto the line off the battery to the switch, run a wire from the switch to the light, and then your ground. For that high of wattage I'd reccomend 2 separate switches, or else take 260 and divide it by 12 volts and find that value, and throw a fuse on. Make sense? We just went over this in my electrical class so if you take that route you're set. Good luck!
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
And use around 10 guage wire, nothing higher(thinner). They tend to melt and catch fire, speaking from personal experience :(....
