Need help with back window!
JCall119
laramie 5.2
I had a sliding glass window untill someone broke the sliding windows so im stuck with my back window being open everday.. -_- I ordered a one peice window that should be arriving anyday now. My question is how do I remove the back window? Ive heard im probably going to have to break it because the seal is next to impossible to cut. Is this true. Has anyone had first hand experience with my truck?
MoparMagic'00
Arkansas
5.2 Magnum
ive not had experience with this but I have done some research as I am wanting a sliding glass instead of the solid... from what i have gathered it is a similar procedure from a reg cab or a quad cab... remove all interior trim surrounding window.. I believe headliner as well... there are supposed to be clips that fold over holding the rear window in place as well as an adhesive bend the clips over (toward glass if im not mistaken) and cut the rear window out... Im pretty sure its covered in the repair manual but im unsure how to set a link to that thread... now im also told the best way to cut it out is with an air chisel with a flat thin blade like attachment.... I would advise having a shop do it for around 100 or so if you provide rear glass because then the work should be under warranty for a period of time incase there are leaks... Good Luck and if you do this repair yourself please do a write up I know I would greatly appreciate it
