clintwinstead
- Jul 23, 2015
- 1
- 0
- 2001
- 5.9 Gas
OK, so I have an 01 Ram 1500, 5.9 gas.
Here is what happened:
I had one good light with no issues on the drivers side, but the passenger side was very dim, and not affected when you switched on the brights. In other words, it burned the same all the time, and not even bright enough to be as bright as the other on dim.
So I got new bulbs, and they do the same thing, making me think it's a grounding issue. I could not see anywhere that the wiring was broke or frayed, so I ran a wire from the ground on the back of the plastic piece where the bulb plugs in and to a bolt on the fender and sure enough, both the lights work on bright an dim.
However when I did they they wouldn't turn off. So I unhooked the wire and have the same original problem of the passenger side light being way too dim.
Has anybody else had this happen?
Suggestions?
Suggestions?
