Need help with v10 magnum ram.
makzy
v10 magnum
engine wont start.
i have already changed
1,spark plug's
2, Fuel pump
3, ecm.
only cylinder number 2 exhaust pipe will heat up
http://troubleshootmyvehicle.com/images/articles-0-99/30/38/image_2.gif
When i turn ignition on asd relay turns on, but it stays that way only 2 seconds positive circuit for injectors stays on same 2 seconds.
i think i need change crank position sensor?
parts are not expensive, but shipping to finland and taxes are...
kris319
Miami, FL
Yea, you'll probably get much more information in the correct section. Goodluck getting it fixed!
Sent from my SAMSUNG-SM-G900A using Tapatalk
KAKA
