Need Help With Wheels
Jdub
I just purchased a 93 D250 and tried to put a set of 2012 Dodge 2500 wheels on it and the offset is wrong. Will spacers work? If so what would be the right spacer?
HemiBabe
DFW
Welcome to RF...
I'm not sure on this one, but I'm sure someone will chime in shortly,
GhostRam94
Hunstville, Texas
2009 Laramie CC
offset wrong.... i think you mean the bolt pattern... our hd guys will know what the correct ones areis
wait will it not go on or is it rubbing.... not sure i read it right lmao
quietpeen
2021 TRX
Hellcat
measure the backspacking of the original wheels and then of the new wheels and the difference would be a good starting point.
89redtta
Tucson, AZ
5.9l cummins
I don't know about the 2012 wheels but i put 2004 2500 wheels on my 92 d250 and used an inch and a half spacer that also changes the studs to the proper size for the factory lug nuts of the 04. They fit great and don't rub anywhere.
