Reproduction SRT10 Wheels
RobHinton
2013 EXPRESS
HEMI 5.7
Afternoon Everyone. I am back after a long absence and I am in the process of purchasing a reg cab. I am interested in swapping out for the 22" SRT10 Wheels. I have seen a lot of your pics which are all awesome. My question is ... some wheels look like they have more of a concave than others. I am ignorant when it comes to wheels so I need help from the experts. Is this a diff in brand? Wheel width? Am I imagining this difference? Any help would be greatly appreciated!
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
R
RobHinton
2013 EXPRESS
HEMI 5.7
Thanks. I am actually interested in the viper type. I wonder if diff manufacturers make diff widths and that is what i am seeing?
MADDOG
Living in a Firepit
6.4L HEMI
They make different widths and different offsets as well.
Start with your stock offset, then look for something close. If you want a little poke, find a wheel that has a lower positive offset or a higher negative offset depending on what offset you are starting with.
Here is where you can find your OEM offset:
Wheel Sizes
Here is a comparator that shows the changes when different wheel widths and offsets are used. You can compare your stock wheels to aftermarket wheels with different measurements.
Wheel Offset Calculator
Bigskyroadglide
Moderator
Use the link I sent and search for the wheel, they make it. I believe it's an 18 offset
R
RobHinton
2013 EXPRESS
HEMI 5.7
THANK YOU. I appreciate all info and any pics+size you all went with would be great !
