Need new tires, one size larger or smaller?
Millnoff
My truck cane with 285/60r20's stock. I want to get winter tires for it, our roads suck up here.
I can get either:
275/65/20 -3/4" taller
265/60/20 -1"smaller
I do a fair amount of towing sleds and wish I had lower gears half the time. Just wondering if that smaller tire will look funny? Or if I'll notice the 3-4% in "gear reduction"
Thanks!
Rick Ram-jet
Big Bear Lake Ca
2016 2500 4x4 CC / LB
6.4 L
Since these will be winter tires, and, based on you wish for lower gearing, go with the 265`s, not only will they give you slightly lower gearing, they will also weigh less....
Probably a good idea to program for the smaller tire size and make sure you get proper E rated tires....
retired
montana
yes they will look funny.
retired
montana
Do you have first hand experience or photos? I have a programmer so changing tire size will be no big deal that way
it is Just my opinion but I think stock size tires look too small on the Ram 4x4 2500/3500's.
Reactions: DOT
tron67j
Maryland
You would be at 3% gear ratio equivalent. You should buy what you want, but that is not much of change and even a 4 sled box trailer, not sure you will notice a difference. One thing to consider, if you out 30k miles on those winters it will equate to about a half million more revolutions of your engine. Have fun with the sleds! Miss mine, not much snow here at all.
DirtyWipers
Kentucky
I doubt you will notice much difference in looks or performance unless you are really seeking out the difference. JMO.
RoadRamblerNJ
Knoxville, TN
392 Hemi
From my experience, driving for 43 yrs in North Jersey snow, a skinny tire is better. Wider tires tend to climb up on top of ths snow and just spin.
The 265 will also slightly help lowering your ratio.
Looks-wise, you need to decide what's more important, getting there or looking good while you're stuck.
Had a '72 Camaro with 12" wide N50/15's on it. Wheel wells flared 5". Come Winter, the old F78-14 studded snow tires went on. They were about 4 or 5 inches wide. Looked stupid as hell but I never got stuck.
You got the ball.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
You got the ball.
Spot on. 100% correct RR
