Need recommendations on rebuilt TIPM
Richmond
Dx that the TIPM is dying on me. Need recs on good supplier for rebuilt TIPM. Last one lasted 6 years, bought from NAPA. Thanks for the assist!
jws123
nj
What are the symptoms that make you think the tipm is going bad? still not as common on the older rams like they are on the 4th gens.
D
Richmond
Fuse burnt out, all three brake lights out; ran the 2 y/o Optima battery down, now the 3 y/o alternator is only charging 14v; headlight went out, replaced with new and won’t work. After each instance, I reset the TIPM and everything works fine. All contacts/pins are clean. I’ve been down this road before.
jws123
nj
It kinda sounds like you have some wiring issues/ a short if your tipms keep messing up its not that common as far as a rebuilder Im not sure because i wind up fixing them myself when they go bad on the newer trucks im sure someone will post.
