Need some help after installing a cam
cvballa008
5.7L
hey, i have a question. at first when I started the truck after the install of the cam and everything, it kinda had valve tap. so i retightened the rockers a little more careful this time and than started it up and she ran fine for bout 15 seconds and than went super loppy on me and than died. and now the only way she will start and run is if i put my foot on the gas. we replaced two sensors because he was getting like a p0108 or something like that. do the rams use an eletric throttlebody? and we just have to perform certaiin steps or do you have any clue? its deff not timing. no kinda back fires. just cant get her to idle
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
What cam did you install? It may just require some driving to allow the adaptives to learn new settings or it may need a tuner to get it right. Mostly depends if the cam is PCM friendly or not.
C
cvballa008
5.7L
comp cam 268.
216 intake/220 exhaust lift
113.0 lobe serparation
New 6.1L springs/push rods.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
What are you using for a tuner? You wont get that 268 to hold idle without tuning.
C
cvballa008
5.7L
im not using a tuner yet. so what kind of tune should i use? so there is nothing wrong with the truck? just need to get her tuned? i guess ill just go ahead and break her in.
C
cvballa008
5.7L
i have a predator tuner.. just no tune actively on the ECU. stock map
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
You are going to need a custom tune for that 268...Even a canned tune from Superchips or Diablo wont hold a steady idle with that cam. Contact Sean at Hemifevertuning.com. He is also a vendor here, so you can shoot him a PM as well. He can get you setup with a custom tune.
Dodge, Jeep & Chrysler Tuning | Jeep Chip | Dodge Programmer & More
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Just saw that you have the Predator. Just contact Sean, and he can set you up with a custom tune to make the truck run correctly.
C
cvballa008
5.7L
ok cool thanks buddy. i appreciate the quick response! i see you live in conroe. know of any places in the houston area. that wont endanger my truck driving it non tuned. just cant really stop at a stop sign lol.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Hemifever does everything through email, so he should be able to get you setup pretty quickly. Its also much cheaper than having a local shop throw it on the dyno. I don't know of any good local Hemi tuners. I know a few guys who have tried, but none of them were able to get the numbers that Hemifever has.
C
cvballa008
5.7L
hey silly question. what are some signs of me putting a push rod into an oil passage instead of on the lifter??
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Sean is the owner of Hemifever Tuning.
HemiLonestar
Navy Badge Coast Guard
MD
No wonder that bugger wouldn't idle...
truckin151
2013 sport
the 268 can either be a breeze to tune or a pita. Sean did the first tunes on mine and had it running alright after a few revisions. After I had it on a dyno & tuned it ran so much better. as said before the 268 WILL NOT run on a canned tune or no tune at all. You can do some damage that way. Did you just do the cam swap or did you do the springs and push rods as well.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
^Ryan hit the nail on the head. Make sure you swapped the springs and rods, tune is a MUST. Your fuel maps are all over the place along with your spark table and injector duty cycles your gonna hurt it. Make sure you have a A/F wideband also to give info to the tuner. DO NOT GO WOT until you have a base tune and the wideband working together.
*Edit
Saw you asking about a rod slipping. Did you cycle the motor over a few times with the covers off to inspect all of the rods were propperly seated.
