Need some help from fellow rambox owners
Damion
2019 Sport
My truck has ramboxes and a factory drop in liner ( plastic ). I usually keep my divider about 1.5 ft from the tailgate so groceries etc don’t slide too far forward.
The problem is my liner don’t have a cutout in this spot. There’s one about 6” from the tailgate and the next is almost half way through the box. And while I can set my divider where I want because of the liner I can’t lock the handle closed on the divider.
I know the box walls have indents for the divider but have no idea where they fall along the box walls except for where my cutout plugs are. So would someone who has the ramboxes without a plastic liner please measure the distances the cutouts are in the box walls ? I just need to know where the measurements were taken from. This way I can cut out my own holes where I usually place my divider.
I have the 6’4” box if it matters
Thanks
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Thanks
Looks to be about 4 1/4" on center...I have the same bed size.542ea9574ca7253488926e583e1c57b7.jpg
Damion
Damion
2019 Sport
Thanks for the pic. Can you measure from the back of the box to where the slots start as well ? I need to figure out the placement of the slots behind my liner
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
From the back of the box (rear of bed) it appears to be 8 1/4" to the center of the first rib and 10 1/4" to the center of the first valley.5229c1484b565c3bb46985b647b28902.jpg170e0dbdf124768dad137a4515e3d963.jpgb8c9bd418c0078b2f2e4ece2c304ebad.jpg4c2a9ed01855158efd5480b1727bdc07.jpg
Damion
Damion
2019 Sport
There we go! Thanks a million. Between those measurements I can figure out where I need to drill to get my divider where I want it
Damion
Damion
2019 Sport
Hopefully this info will help out someone else with the same issues.
SETEX 6.4
Port Neches, TX
If it was me I would just pull the crappy plastic liner out and throw it in the garbage. When and if the bed gets to scratched for your liking, have it sprayed.
This way you can use all the available slots that make having the Ramboxes and it's devider system so awesome.
2014 Ram 2500 Mega Cab 6.4 Hemi 4:10 Gears Ram Boxes 35x12.50R18 on Factory Wheels
Sent from my SAMSUNG-SM-G891A using Tapatalk
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Would you mind posting a picture of the liner? I'm surprised they would make one that removes most of the divider adjustments...
Damion
Damion
2019 Sport
The only issue there is there’s no one around here that does spray in liners. I wouldn’t do a Diy.
At the least I’d have a bedrug. I honestly don’t mind plastic liners.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
It sucks that bedrug decided not to make one for our configuration...
Damion
Damion
2019 Sport
E6C680FD-E59D-49D3-BAD4-4196F0C1F1FB.jpeg Not my truck but this is the same liner I have. It’s a mopar part and is riveted in. As well as being under the cargo rails.
I’ll have to measure tomorrow but I think those little nubs are markers for the ribs
