Need some wiring help, puzzled
Catchin Zs
Wilmington, NC
Alright so I got my switch panel mounted yada yada yada I'll get a thread for that later. It came with 5 of these buttons, each come with 3 wires, a red, a black and a tan. Here is the diagram I found online for them. Here's what the site that makes these buttons says: the black wire goes to ground, the red wire goes to your constant power source, and the brown wire goes to the circuit you are powering.
I want to hook these up to these two wires. Yellow is connected to the relay, black is connected to the positive battery cable with a fuse near the firewall.
So with the diagram in the first picture, which wires from the buttons do I hook up to the two in the second picture?
HemiBabe
DFW
I'm sure someone will chime in soon :)
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Red to black
Brown to yellow.
If you want to, the black on the switch should be to allow the LED in the button to light up, so just ground that one somewhere.
