I just put yellow stuff pads on mine, i read somewhere from ebc the yellow especially like to be mated to a new surfaced rotor, I reallllly wanted ebc rotors but my wish list is to long to drop the cash on those yet, but they were first choice. I did change from factory to Powerstop z36 rotors, drilled and slotted. Only complaint is the z36 rotors are already rusted on the outer perimeter surfaces, where the cooling air enters the rotor. About a year on the front set. Garaged and washed way to much, CO uses mag chloride (I believe) on the street, so maybe that was a contributor but aside from that, bang, the yellow and z36 stop my wagon like no other brake I've ever run.
The z36 is the least expensive performance oriented rotors I found, and you have a choice of smooth or slotted..
Do follow the instructions for bedding the pads, the procedure kinda sucked, I guess I would mark that as a negative. Drive gently for 200 miles (??) Then 65mph to 10mph as hard as you can 10 times - not my style. I made it six times, and that was enough of that crap, but now my favorite.
I still want ebc rotors next time but extremely happy w current setup, especially for the price.
'16 Wagon Greene tune feed'n & fire'n 6.4L with 6spd • 5.13 AAM, 37" KM3, -12mm Fuels • Thuren Overland, DOR, Purple Cranium • CAI, ARH, Solo Mach44 • z36, EBC • Custom vinyl AVS, 4% tint • Morimoto, Rigid, Diode Dynamics • AlfaOBD, Diablo, Nanny Kill, Locker bypass •.................
