If you are looking for the canbus connectors, they are super easy to find. Remove the Drivers Interior Knee Kick Plate (The big square plastic under the steering wheel, which has the round opening that either the key or the push start goes thru. Take the 2 screws off the bottom, and pull towards driver seat and upwards.
Right below the steering column a bunch of wires go into a big "foam" something. That foam "something" which is gray cellular foam is about 3" or 4" long by about 2 inches wide and has some electrical tape around it. Underneath that foam (cut the electrical tape to open it up) is the canbus hubs, both high and low. The High have white connectors, the low have green connectors.
