Need to know where to replace fuse or module with an led relay module?
MON5T3R49R
New York
Administrator
what lighting are you trying to fix?
Chances are it's not a fuse and all the lighting is controlled by the BCM so there is no LED relay module. You'll need to use AlfaOBD if possible to correct for the LEDs, add load resistors or use different LEDs.
M
MON5T3R49R
New York
Replaced all front end with led, now I have a hyper flash from the blinkers in side mirrors when using each side.
M
MON5T3R49R
New York
Only started after I put in switchbacks for parking light/blinker
