What's the reasoning behind no synthetic for the 5-6k?? I run an automotive shop and all these rumors between non and synthetic I have found to be myths. If your vehicle is gonna leak oil, it's gonna leak oil regardless of what ya put in it. The only difference is that synthetic is more resistant to molecule break down but should still be changed just as often due to the fact that it still collects the same amount of dirt.
I want to get a proper break so I want to break it in with dino and then move to syn based oils. It has NOTHING to do with leaks.
I've followed this method now several times.
Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
If the dealer puts in DINO then why change it as you stated earlier?
Did you read the info in the link I posted? Check out all the Q&A's.![]()
I know a LOT of guys on various forums that use this method and have had great luck with it. I'm not saying it's the absolute gospel, but it's worked well for me and others.
