New 75 power wagon owner
Dieselholic92
Lynd, Minnesota
360, 5.9 Cummins
That's either an older Edelbrock or a Carter AFB. Pretty much the same carburetor either way
L
lostboy03
Lemoore CA
360 cid
New distributer fixed the problem.
Now I am running real low oil pressre. Changed out plastic line to brass. Changed oil and bled the oil guage line. I belive I have a leak where the line plugs into the back of the motor but waiting for the weekend to trace.
also I have what looks to be a smaller plate missing on the inspection plate in front of the trans on the lower side. Anyone seen this. Again I have a W100 W/ a 360 cid.
BLACK ACTUAL
I have the same rig, same year, same motor, same problem.
When I had the engine rebuilt , they replaced the cap, rotor, wires etc but did not replace the original distrbutor. They also forgot to hook the vacuum line to the vacuum advance on the distributor so it caused some other problems.
I need a new distributor and I need to get my vacuum lines situated since I am also running an aftermarket edlebrock 4bbl carb with an electronic choke.
