New and have a Tire Question
Bcdur12
Pittsburgh
2014 1500 Express
Hello,
New to the forum and just had a question. I have a rough country 2 inch leveling kit on my 2014 Ram. I am looking at getting 33 12.5 r20 tires out on it. My question is do I need wheel spacers or will I clear everything with the leveling kit.
Thanks
4xdad
Edmonton Alberta
2015 powerwagon
welcome to the club. wheel spacers are not a good idea imho. i had a 4door jeep and i got one that had been rolled. it had brand new 33s but the wheels weren’t the same as my jeep so i opted for wheel spacers. long story short i got a panic phone call from the wife that the wheel had fallen off the jeep as she was booking down the road. when i got it home it was obvious what happened the studs broke off. i bought best ones i could find i will never do that again.
olyelr
Kewadin MI
I believe 12.5” wide on some factory wheels will have the tire rub on the upper control arm. Measure the distance from your current tire to the ball joint area of the control arm…there has to be room for half the width of however much wider the new tires will be.
olyelr
Kewadin MI
so according to my friend who has a 12 1500 with 33s they do rub but not super hard
The 4th gens come stock with 33’s. The issue is the width…especially with factory wheels. Its not an issue with rubbing body, its that the tire rubs on the control arm and you cant even drive it unless you put spacers on.
4xdad
Edmonton Alberta
2015 powerwagon
so different rims needed. imho never use spacers. others may say it’s fine but in my experience they are a disaster waiting to happen
Rt71668
Long Island
Hello,
Thanks
I have the same setup on my 2017 no spacers no issues!
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Hello,
Thanks
Get the equivalent tire in a metric size, like
Tire Size Comparisons
The table below compares the two closest standard metric equivalents to your 33 × 12.5 × 20 tire size:
Tire size
33 × 12.5 R20 (Your Size)33.0 in (83.8 cm)12.5 in (31.8 cm)20.0 in (50.8 cm)
315/50R20 (Closest Width)32.4 in (82.3 cm)12.4 in (31.5 cm)20.0 in (50.8 cm)
305/55R20 (Closest Height)33.2 in (84.3 cm)12.0 in (30.5 cm)20.0 in
I'd go 305/55/20. 12 wide should clear on a stock rim, where as a 12.4 could rub and require spacers.
I know I put 315 70 17 on my 24 warlock, and I had 3/8 clearance to the front upper control arm, so I added a 3/8 hub centric spacer for additional clearance.
Warlock has a 1.4 inch front lift from the factory. Same as the outdoorsman
