Which series odyssey battery are you running ? TksAsking about what battery to use is about one step under asking what oil to use.
Whatever you buy, consider switching to an AGM type battery instead of a flooded cell design.
Your truck uses a H7 size battery with a 730 CCA rating. You can go with a higher CCA rating and you can even use an H8 size battery.
I'll throw my hat in the ring, I'll recommend Odyssey batteries, they're a little pricey but made here in the US. The Odyssey part for your truck is: 94R-850 or you can use the same one as in my EcoD which is a 49-950.
I have always had great luck with the OEM battery from the dealer. They cost less than most aftermarket batteries and last a long time. I replace them every 6-7 years and have never had one fail me.Looking to get a new battery for my 2017 1500. 5.7l. What is everyone getting?
It's the Performance series, I don't believe they offer an Extreme version in the correct Group/DIN size(H7/H8) that fits the Ram trucks.Which series odyssey battery are you running ?
Just an FYI about battery sizes for those looking at different batteries. The LN4 is the European Norm size or referred to as the EN Code. It's sometimes shortened to just L4 and is the equivalent of an H7 (DIN size) battery.AGM94r-850 LN4-H7
IF you're not planning on a bigger electronics load , would going up one size be a BAD thing? At all? Sorry I'm a 49 yr old newb here.Odyssey AGM94r-850 LN4-H7
Some guys like upsizing to H8 to add a bunch more electronic loads, subwoofers, etc.
