New cat back for $300?
Odin
Arizona aka HELL
Hemi 6.4L
Did a quick search for reviews and it looks like it's spotty. One guy had packing coming out his tips 3 MO after install.
Sent from my SM-G950U using Tapatalk
G. Mcpherson
Vancouver, Wa.
2023 Ram 2500 CC SB Tradesman
Say's 3" inlet . Should be 3.5". Most likely better values elsewhere.
Meister
Meister
Peyton colorado
6.4 hemi
The 3.5 inch is pretty hard to find . Not sure where better values are for a dual set up. Just seems odd, I am having a flowmaster 50 with resonator delete put in, but just threw this out there as a bolt on kit.
The other brand trucks use 3inch exhaust for hd trucks, seems to be the most common size to include 1 ton
Keep in mind the hemi needs some back pressure to keep its torque up, unless you want to lose performance.
So for $325 you buy a reducer from the cat and have a dual exhaust, so theoretically its 6inches of flow for the 6.4
Low_Sky
6.4L
A three inch dual exhaust would be equivalent to a single 4.25” exhaust. You don’t double the diameter, you double the flow area.
Meister
Meister
Peyton colorado
6.4 hemi
Regardless its bigger then the 3.5inch that was my point.
