New front bilsteins
jljbtm
I installed the new front bilsteins on my truck and set it to the second Notch from the top then I took it to the shop to get the wheel alignment checked they called and said they need to change the upper essentrics cuz the toe-in is too exaggerated. I thought II setting was okay and didn't need anything extra
Sent from my SM-N910V using Tapatalk
huntergreen
Marine Corps Navy Badge
have never heard of this being caused by the 5100s.
12sportmc
NC
Might try another shop for a second opinion
jljbtm
jljbtm
I will have a 2nd. opinion.
I though, all the threads I've read on this subject said nothing else was needed unless you went all the way up? Then you would need different upper control arms.
BiGMERF
2017 SLT 4x4
v6
im at 2.1 , no issues
muddy12
Indiana
I'd find another shop.
The toe adjustment is set by adjusting the tie rod ends, Not the eccentrics on the upper control arm.
daveray9
Weird. Keep us posted!
Sent from my SM-G920V using Tapatalk
lharrell79
Did you install the coil cup in the right direction on the Bilsteins?
jljbtm
jljbtm
Absolutely, I also called and talked to their tech guy and he said you really don't have to do anything else. Even on the top setting you don't really have to change the upper control arm.
EagleChief
Oklahoma
2014 Big Horn
You have read and researched correctly. Find another shop, for sure.
I'm at 2.1 for a little over a year with no issues. The shop I went to had no problems doing the alignment.
jljbtm
jljbtm
So I did take it to another shop and they aligned it with no problem, that first shop either didn't know what they were doing or wanted to sell me something I didn't need
