New gears
allenw88
Aurora, Colorado
So I am looking to upgrade the gears in the rear diff. What should I be looking at. I don't want to go crazy. maybe just a bump up. 3.90's maybe? Just something to help out a little bit.....
Any links to see what I need to look at getting would help out as well. Thanks.
I have an 2005, 1500
Gecko
NJ
5.7L Hemi, 8.3L V10
What are your stock gears? 3.55? The next up would be 3.92s but I'd say go with 4.10s instead. Or you could really have some fun with some 4.56s. Also are you 4x4 or not? Cause if you are you'll have to change both front and rear.
MegaMouseGW
South Louisianna
SRT 10 Viper Motor and Tranny
I want to add this. When you change the gears in the rear end you will have to have your speedo recalibrated. Speeding tickets are a pain in the tail end.
rustydagger
Near McAlester, Oklahoma
hemi 5.7 with K&N CAI and Diablosport Trinity Tuner
I'm under the impression that the speedo will not need recalibrated. It reads off of the tire speed sensors and is only thrown off by changes in tire size.
From what I understand anyways. :hidesbehindsofa :)
Or do the 2005's work differently than that? I should've read closer the first time. :p
MegaMouseGW
South Louisianna
Most newer vehicles and a lot of older ones have the speed sensor in the transmission. Yes you have to recalibrate the speedo when you change tires if the physical height of the new ones is more than 1 inch difference, but changing the gears also requires a speedo recalibration. Most tuners have the ability to recalibrate the speedo. I installed 3.96's in my daughters truck from the 4.10's and had to do a bit of digging but found the correct menu to do it with the Intune I have on her truck (she did not need the 4.10's because she does no towing).
TylerB
FL
The speedo does not have to calibrated for a gear swap only a change in tire height. Our trucks read off the tone ring in the axle not the transmission.
allenw88
allenw88
Aurora, Colorado
I have the 3.55's right now. I was looking around on Rock auto and came to the conclusion that 3.90's were the next up. The only thing I will be towing would be a boat during the summer months. Just a regular fishing boat. I don't have 4 wheel drive. So yeah.. I'll prolly go with the 3.90's I see on RockAuto
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I have a 2wd and do very little towing. I have the 4:10 gear with short 28 inch tires and IMO it's perfect. If I ran taller tires such as 31 or 33" I would prefer 4:56. IMO don't waste your money on 3:92's. And as stated Moe's is the best source for gears and install kit. Good luck..
Redhemi03
Banned
Denton tx (Dallas)
2003 and 2013
5.7 in both
I have a used set of 3.92's that came off my truck when I went to 4.56's, holler at me if you would like to pick them up. Ill let them go fairly cheap
Barracuda556
How much difference did anyone notice going from 3.92 to 4.10s?
Redtruck-VA
Virginia
As you can tell from the ratio's there isn't much difference. A lot of folks will go from 3:55 to 4:10. Most folks with 3:92's will opt for 4:56.
joshhhh
