New Headlights!
Dippinchick
So I had a late night shopping spree that I barely remember, bought headlights apparently. Just put them in and it was super easy! Not plug and play, had to sauder on extension wires and make some connectors but they turned out awesome. I love them!!
Jake2544
MA
Did you borrow my wire strippers without asking? Looks good!
OnSale
5th Gen Crew
Philadelphia, Pa
Looks good. Not a fan of that style eBay lights but they came out looking good.
Sent from hell via TapATalk
BlownGP
Houston/Baton Rouge
You had to solder the wires for halo rings? Should have just used some T-tap connectors.
Dippinchick
Dippinchick
Didn't have to, soldered extensions into original wires so now it's just plug and play for the future
OnSale
5th Gen Crew
Philadelphia, Pa
But now your trucks wires have been cut and reconnected. You should have either used scotch locks or bought the Halo Adapters from JJ. That way your trucks oem harness remains in 1 piece.
00R/T
CT
The harness wasn't cut. It was tapped the correct way. Done properly, this method is far superior to any sort of "tap" connector. There's a reason why the factory specifies wires should be tapped this way.
12sportmc
NC
@OnSale- ya man 00R/T is right...the OP did this the right way and way cheaper than buying an adapter. Solder is the best way to connect wires...it's what I do for a living so I'd say that makes my opinion semi count lol. It's like welding metal but for wiring.
To the OP excellent job lights look great
Dippinchick
Dippinchick
Lol I'm a 20 year old girl first time doing this so thanks for the compliments on my first attempt!
BlownGP
Houston/Baton Rouge
But the wires had to be cut to be soldered. It is the "proper" way to do it but T-taps make for a easy removel.
Addis daddy
Levittown
The wires were stripped back not cut, anyways nice job to dippinchick on your install.
How is the output of light? And did you use factory bulbs or go with HIDs?
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
T-taps are terrible always allow corrosion and bad connections in the future. Solder is sure to make a great connection that will last. I remember when I bought my boat they had used t-taps and then electrical taped over them. Garbage! Ended up pulling the whole wiring harness in out of the trailer replacing the whole thing and then using heat shrink tubes and solder to make a fail proof connections to each light. Works perfect and can handle moisture over and over again.
