New hub assembly.
wvfd114
I replaced my passenger front hub assembly. Now the abs, traction and esb lights are all on and the service 4wd and etc. everything was installed correctly and connected. Only drove it 300 ft. Is something wrong or does the truck need to learn the new sender?
Brandon-w
Yukon
2015 Ram 1500
Try driving it further. Might have been powered on and recognized that there was nothing hooked to that hub during instill. Usually takes a km or two to reset its self. Or disconnect battery for a bit to clear it and then see if it comes back.
Sent from my SM-A530W using Tapatalk
W
wvfd114
No dice, left the battery off all night. Hooked up no different.
huntergreen
Marine Corps Navy Badge
Recheck the connections, if all is good just drive and see if it resets.
psy_lt
Any luck on your problem. I’m having the exact same issue after replacing the front hub assemblies.
RamCares
n/a
n/a
Hi psy_lt,
We understand why this may be concerning. We suggest having your dealer inspect this concern if you have not done so already. We are also available via private message if you would like any additional assistance during that process.
Lydia
Ram Social Care Specialist
psy_lt
Hi psy_lt,
Lydia
That's just silly, who takes their truck to a dealer? Not anyone who likes money. But yes, still having the same issue. Luckily I am commuting to my new job so I don't need need the truck at the moment.
