New member - heat problems
johnnyg23
Annapolis, MD
Hi guys, brand new here to the forum. I have a 99 Dodge Ram 1500 4x4.
My problem is I have great heat when driving, but when I stop at a traffic light or stop sign, the air gets cool. I checked the coolant level and it is full. I was told it might be a thermostat or maybe even a heater core issue. Can someone help?
Mopar1973Man
New Meadows, Idaho
1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
Ok...
So double check your coolant temp and make sure the thermostat is reaching it mark. Like if you got a 180*F it shoulf be close 178-182*F typically on cold days.
Then withe engine fully warmed up and heater on high check the coolant hoses to and from the heater core. If there is temp difference there is good flow of coolant. If both hoses are hot then the heater core is plugged up and not flowing good.
You might have to check the blend door motor for proper function too.
Clifford
St.Francis, Minn.
97 Ram 2500 Club Cab Long Box
5.9L Magmun
Id lean toward the heater core- 99- 100K?
Sounds like a flow issue. check the hoses for temp difference?
J
johnnyg23
Annapolis, MD
It has 128k miles on it. Thank you for the replies guys. I will look into it. Is the heater core something I can do myself or should I seek help? Can I wait to change it out or will I risk something really going wrong?
rambob
LA/MS
318 5.2l
is your dash cracked at all?
if so, there is a good chance it will be ruined when you remove it to replace the heater core.
from what I have read, it is not difficult, just very time extensive
rambob
LA/MS
318 5.2l
if you do not require to use the heater, you can bypass it with the heater hoses.
you will have no heat though.
J
johnnyg23
Annapolis, MD
Thanks again for the replies. My dash is pretty non-existant. The previous owner had a bit of road rage one day and smashed the hell out of it. lol. A few more broken pieces won't hurt it anymore.
Clifford
St.Francis, Minn.
5.9L Magmun
5/8" female garden hose end-
pull BOTH heater hoses off the nipples @ firewall, hook hose to one side and flush... should remove blockage
Hook back up and run- purge air from system and enjoy heat again...
Clifford
St.Francis, Minn.
5.9L Magmun
Heater core unplugger
this is what I use...
Raadz
