homerfan1
- Sep 28, 2014
- 1
- 0
- 2001 ram 1500 4wd
- 5.2
I just purchased a 2001 dodge ram 1500 4wd with the 5. 2. The truck has sat parked for 2 years. When I bought it I put a battery in it and drove it home although it ran it ran rough with no power. So once I got it home I put some fresh gas in it.changed the plugs wires cap and rotor. Also replaced the air filter, pcv valve and changed the oil.. still runs rough with not much power. When I drive it down the road I get a cel saying misfire on several cylinders. I have not tested fuel pressure yet. But that's what I'm leaning towards. ANY IDEAS from you guys???? I did find a few vacuum leaks and repaired. Not sure what else to do.does anyone have a diagram on the distributor and the firing order so I can make sure I have that right. Thanks again for any help.
